Weir height test case (Water Module)
This page contains information on what ways a weir's height can be configured using a test case. It also shows what direct output you can inspect from a weir. Finally, several variants are also explored.
Description
This test case consists of several weirs situated in a waterway, with each weir having different properties. All weirs are part of the same Water Overlay's simulation. There is no rainfall in this test case. Instead water flow is provided by inlets and outlets, which can be set up either variable or constant.
Weir test case top down.
  • Waterways with weirs in the middle, separating two water areas.
  • One inlet per waterway providing an influx of water, situated in the water area on the left.
  • One outlet per waterway providing an outflux of water, situated in the water area on the right.
Parameter values
  • Manning’s n: 0.03 (uniform)
  • Model grid resolution: 1m
Technical setup
Waterways
Four waterways with a water depth of 2m and an angle of repose of 35 degrees, drawn with the following polygons:
  1. [187.0, -249.288], [418.0, -256.288]
  2. [413.0, -333.288], [189.0, -326.288]
  3. [194.0, -375.287], [411.0, -382.287]
  4. [404.0, -447.430], [194.0, -440.430]
Water Areas
Two areas divide the water ways into two sections:
  • Water area (left)
    • Rectangle shape: [301.0, -226.466], [158.884, -464.466]
    • WATER_LEVEL = 0.0;
  • Water area (right)
    • Rectangle shape: [424.884, -226.466], [301.0, -464.466]
Inlets
Inlet Q that is adjusting over time, visualized using the Measurement Tool's object attribute inspection.
Outlets
Each outlet is set up with the following attributes to remove the water that passed through the weir:
The outlets are situated at:
  • Outlet (Constant):
    • Rectangle shape: [414.554, -250.689] , [396.786, -253.873]
  • Outlet (Manual):
    • Rectangle shape: [410.115, -327.753] , [ 393.13, -330.9620 ]
  • Outlet (Adjusting):
    • Rectangle shape: [ 401.072, -442.541 ], [ 383.968, -445.520 ]
Weirs
Each weir is setup using a rectangular shape, and direction angle and a weir height and width:
Weir specific:
  • Weir (Constant)
    • Rectangular shape: [ 299.593, -248.328 ] , [ 302.229, -257.983 ]
  • Weir (Manual)
Weir height that is adjusting over time, visualized using the Measurement Tool's object attribute inspection.
    • Rectangular shape: [ 298.675, -324.174 ] , [ 301.613, -335.662 ]
  • WEIR_HEIGHT = [ 0 0 600 0.2 1200 0.2 1500 0.2 1800 -0.5 2400 -0.5 2700 0 ];
  • Weir (Adjusting)
    • Rectangular shape: [ 298.406, -437.681 ] , [ 301.142, -449.731 ]
Overlay settings
General parameters that have been used:
Output
Measured object graphs are displayed below.
Weir with constant height
    Weir with a constant height:
  • Inlet:
  • Outlet:
Weir with manual configured changing height
    Weir with a manual configured changing height:
  • Inlet:
  • Outlet:
Weir with adjusting height
    Weir with an adjusting height:
  • Inlet:
  • Outlet:
Variations
Weir adjustment interval
Changing the WEIR_MOVE_INTERVAL_S from 10 seconds to 1 second:
  • Inlet: No changes.
    Outlet:
Weir move step
Changing the WEIR_MOVE_INTERVAL_S from 0.01 meter to 0.05 meter. As you can see, this makes the adjustments more erratic.
    Outlet:
