| Icon |
Attribute |
Unit |
Range |
Description |
Default value |
BRIDGE_ELEVATION |
nominal |
Specifies the mode by which bridges are include in the elevation model, used for the water calculations. |
Lowest |
| 0. |
Lowest: Lowest elevation point from Terrain below bridge is used.
| 1. |
Terrain: Use standard elevation from Terrain. Bridges are excluded from the DEM, allowed water to flow as if they didn't exist.
| 2. |
Bridge : Use bridge deck as elevation. Bridges and floating Constructions are included in the DEM, blocking water flow.
- When using Bridge mode, it is still possible to model the flow from one side of a bridge to the other by using a Culvert.
Videos
Explanation of how bridges are made water permeable in the Tygron Platform. (In dutch)
Explanation how to deal with bridges and the elevation map in your water system. (In dutch)
