How to import a SketchUp model in ArcGIS Pro
Revision as of 15:19, 30 January 2024 by Frank@tygron.nl (talk | contribs)
Below the steps on how to import a SketchUp model from the 3D warehouse from SketchUp in ArcGIS Pro.
How to import a SketchUp model from the 3D warehouse in ArcGIS Pro:
  1. Download a SketchUp model from for example the 3D warehouse as a KMZ file.
  2. In ArcGIS Pro click in the Map tab on Add Data and select the KMZ file.
  3. Click in the Analysis tab on Tools and search for the tool: KML to layer.
  4. Choose the KML layer as input file and choose an output location and name. Run the tool.
  5. A new layer file is added to the project. Choose the multipatch layer and right click on the Multipatches layer and choose properties.
  6. Select the Elevation tab and select On the ground and then Ok to place the model on the surface terrain.
Below the steps on how to correctly export a SketchUp model for creating a SLPK file.
How to export a SketchUp model:
  1. Save the SketchUp model as a SketchUp 2015 SKP file.
  2. If you would like to have the objects as separate geometries in the Platform, then explode the model.
  3. Then export the 3D model as a AutoCAD 2004 or release 14 file and make sure to check the Faces for exporting.
  4. After the file is exported, import the DWG file in ArcGIS Pro.
<<Back to SLPK manual
