Bowen ratio (Heat Overlay)
Revision as of 10:08, 17 October 2025 by Rudolf@tygron.nl (talk | contribs)
The Bowen ratio[1] is a property of a surface, specifically the ratio between two types of heat transfer (sensible heat and latent heat). The wetter the surface, the lower the ratio.
  • The DPRA Heat stress report uses only two possible values for the Bowen ratio: 0.4 and 3.0.
  • By default, Functions such as trees and vegetation generally have a ratio of 0.4. Other functions have a ratio of 3.0.
  • The value must be in the range of 0.001 to 10.
  1. Bowen Ratio ∙ Wikipedia ∙ Found at: https://en.wikipedia.org/wiki/Bowen_ratio ∙ (last visited: 2019-12-16)
