How to add an Event to an Answer of a Panel
Panels can be assigned Answers, which allow an end-user to interact with a Session based on the information provided in the Panel. Exactly what interaction takes place must be explicitly configured.
How to add an Event to an Answer of a Panel:
- Open the list of Panels.
- Select the Answer you wish to configure
- At the bottom of the right panel, select "Add Server Event" or "Add Client Event", depending on the intended Event.
- Select the now added "NO_DEF" Event.
- In the bottom panel, select and configure the desired Event.
- In the bottom panel, click on "Commit".
- Selecting the Answer will now effect the intended interaction.
