IFC
The Industry Foundation Classes (IFC)[1] is a CAD data exchange data schema intended for description of architectural, building and construction industry data.
IFC (*.ifc) files can be imported into the Tygron Platform.
Version IFC4 is supported, earlier versions (e.g. IFC2x3) might contain errors.
Supported Spatial Structure Elements
An IFC file can consist of a hierarchy of spatial structures. The following spatial structure elements are currently supported:
- IfcSite, IfcBuilding, IfcBuildingStorey, IfcProduct
Not every element is imported for these spatial structures. The following element types are accepted:
- IfcBuildingElement, IfcGeographicElement, IfcDistributionElement, IfcElementAssembly, IfcTransportElement, IfcFeatureElement
Supported Representations
The following representations[2] are supported:
- BoundingBox
- SolidModel
- ExtrudedAreaSolid (using Profile Definitions)
- FactedBreb with FaceBounds: EdgeLoop or PolyLoop)
- MappedItem
- Curve:
- Polyline
- IndexPolyCurve
- TessellatedFaseSet:
- TriangulatedFaceSet
- PolygonalFaceSet
Profile Definitions
The following profile definitions[3] are currently supported:
- ArbitraryClosedProfile (outer and inner curves)
- ParameterizedProfiles:
- CircleProfile (incl. hollow)
- CShapeProfile (excl. fillet)
- EllipseShapeProfile
- RectangleProfile (incl. hollow)
- IShapeProfile (excl. fillet)
- LShapeProfile (excl. leg slope, fillet and edge radii )
- TShapeProfile (excl. fillet, flange-edge, web-edge radii and web and flange slopes)
- UShapeProfile (excl. flange slope, fillet and edge radii )
- ZShapeProfile (excl. fillet and edge radii)
Styles
By default, IFC features will be colored in Light Gray. The following styles are supported that can override this color:
- Surface styles: IfcSurfaceStyleShading; with style that has a SurfaceColour defined.
- FillAreaStyle: IfcColourRgb and IfcPredefinedColour; both reference colors directly.
Textures are not yet supported.
Test your model
You can test your IFC model by loading it into this online tool: https://viewer.flinker.app/
- How to import an IFC file
- How to export Revit models to IFC
- How to export Sketchup models to IFC
- How to export Blender models to IFC
- ↑ IFC ∙ Found at: https://technical.buildingsmart.org/standards/ifc/ifc-formats/ ∙ (last visited: 2025-09-01)
- ↑ IfcRepresentations ∙ Found at: https://ifc43-docs.standards.buildingsmart.org/IFC/RELEASE/IFC4x3/HTML/lexical/IfcRepresentation.htm ∙ (last visited: 2025-09-02)
- ↑ IfcProfileDef ∙ Found at: https://ifc43-docs.standards.buildingsmart.org/IFC/RELEASE/IFC4x3/HTML/lexical/IfcProfileDef.htm ∙ (last visited: 2025-09-02)
