Inlet (Water Overlay)
Waterwizard icon inlet.png An inlet is a point-based constructions. Template:Overlay attribute
  • Each Inlet attribute functions as a limit to the flow. If multiple are defined, the flow is limited by the strongest limit. If neither an INLET_Q or any threshold is defined, there will be no flow.
  • A negative INLET_Q changes the Inlet to an Outlet.
