Culvert (Water Overlay)
Culverts are assumed to have a spherical cross-section.
Icon Attribute Unit Description Default
CULVERT_DIAMETER m The diameter of the culvert. For throughput calculations, the culvert is assumed to have a spherical cross-section. 1
