Sewer overflow (Water Overlay)
A sewer overflow is a point-based constructions. It must intersect with a Sewer area and a water level area, but does not need to intersect with an actual sewered construction. Template:Overlay attribute
Note
  • At most one overflow can exist per sewer area.
  • Water will flow when the water height in the Sewer is larger then the Overflow Threshold.
  • Sewer overflows will only be created when all sewer areas in which a sewer overflow is placed also intersect with a water level area.
