Results (Water Overlay)
When a simulation for a particular Water Overlay is completed, the results are stored as numerical values in a grid spanning the project area. The stored values and their context depend on the selected result type. These grid results are not only stored for the water overlay, but also for its related result child overlays. Additionally, apart from the end result, multiple intermediate timeframes may be generated and stored for each result child overlay.
To find out what possible result types the water overlay has, see the list of possible result types of the water overlay.
However, the Tygron Platform provides more output for the water overlay to gain further insight into the performed simulation, to verify and visualize it.
Visualize results
Overlay visualization
Timeframes
- Main article: Timeframe
Note that the simulation time is divided into an amount of periods, and at the end of each period a timeframe is recorded. This means the first timeframe is not a snapshot of the initial state of the simulation, but a snapshow of the state of the simulation after the first period of time has passed already.
System visualization
Depending on whether the option is selected, the hydrological system can be visualized when when the overlay is activated. Each water level area will be visualized by a striped border along the surface of the terrain. If a sewer exists, and the sewer has a sewer overflow, the overflow is visualized with a black spehere, and an orange line connecting it to the center of the sewer. Culverts, weirs, and pumps are visualized by green, orange, and red spheres respectively for their endpoints, connected by blue lines. Inlets are visualized with an orange sphere.
If water has flowed through any of the hydraulic constructions, animated arrows in the connecting lines will indicate that movement.
Weather visualization
Inspecting results
Hover panel
- The ground height, which is the terrain height relative to datum.
- The output value of the overlay, which is dependent on the selected result type.
- The hydrological properties of the terrain (if applicable), such as the applicable manning value and infiltration speed.
- The hydrological properties of features (if applicable), such as water level, inundation level, and terrain height (which may differ from the base terrain height due to elements such as a breach).
- The hydrological properties of constructions (if applicable), such as building storage, and |sewer storage of sewered buildings.
Measuring tool
- Main article: Measuring tool
While viewing the overlay, a general impression of the values can be seen at a glance. However, depending on the configuration of the overlay's legend the exact values may be difficult to view exactly. Using the measuring tool it's possible to retrieve the values of the overlay on exact locations. Additionally, cross-sections can be defined and easily have their values inspected.
Water balance
| Input | Output |
Debug info
After the calculation completes, some additional information is tallied and output for debugging purposes. This is intended for verification that the model has computed as expected, and may provide some basic information at a glance. It is not meant as a primary tool for in-depth analysis of the results.
The following information is displayed:
| Debug info |
Input overlay
- Main article: Average Overlay
The water overlay's calculations rely on multiple geographical parameters, such as manning values and evaporation factors. To help with both understanding the outcome of the calculation as well as verifying the results, the configuration wizard offers the option to add input overlays to the project, which are Average Overlays configured to display the input parameters geographically.
Overlays such as these can also be created manually, by creating an Average Overlay and configuring it such that it functions on the desired attribute, and with an as small an averaging distance as possible. Optionally, a specific layer (such as constructions or terrains) can be configured which the overlay should inspect.
TQL
- Main article: TQL
Storing results
A number of output forms don't fit in the analysis structure described above, but can provide additional information or insight into the calculation. These can provide different ways of looking at both the input and output of the simulation. They are offered as a means to further visualize but also verify the performed calculations.
Exporting Geotiff
- Main article: Grid overlay
Storing specific overlay result
