Pump angle (Water Overlay)
Revision as of 09:25, 19 December 2019 by Bobby@tygron.nl (talk | contribs)
Template:Overlay attribute
The image displays the principle for a weir. The same principle is applied for a pump.
  • This angle is used to generate a line for the front and end points of the pump. Additionally, the elevation is also automatically adjusted for the region perpendicular to the pump angle.
  • If no angle is available as an attribute, the angle can be calculated by using the Generate Angles option in the Pumps step of the wizard.
