Culvert (Water Overlay)
Culverts are assumed to have a circular cross-section, and level (i.e. not inclined).
Waterwizard icon culvert.png A culvert is a line-based construction.
Icon Key Unit Description Default
Waterwizard icon culvert width.png CULVERT_DIAMETER m The diameter of the culvert. For throughput calculations, the culvert is assumed to have a circular cross-section. 1
Waterwizard icon culvert height.png CULVERT_THRESHOLD m + datum The height of the inner side of the culvert's underside (or the threshold height at which water starts flowing through the culvert). When set to a level below the terrain height at either end-point, the culvert's height will automatically be treated as a value equal to that of the highest terrain found at either of its endpoints. 0
Waterwizard icon manning.png CULVERT_N s/(m1/3) The manning value of the culvert's material, which influences the flow speed. 0,014
  • If a culvert is placed in a waterway, and the waterway is not otherwise interrupted, water will be able to flow past the culvert via the waterway itself. It is recommended to make sure that the waterway is obstructed by an increase in the terrain height in such a way that the only way water can flow from the one end of the culvert to the other is via the culvert.
