Inlet (Water Overlay)
Revision as of 11:28, 8 May 2020 by Frank@tygron.nl (talk | contribs)
An inlet is a point-based construction. Template:Overlay attribute
- Each Inlet attribute functions as a limit to the flow. If multiple are defined, the flow is limited by the strongest limit. If neither an INLET_Q or any threshold is defined, there will be no flow.
- A negative INLET_Q changes the Inlet to an Outlet.
- The lower and upper thresholds can be seen as a the lowest and highest of "range" of valid water levels. If the actual water level does not fall in the specified range, the inlet will allow water to flow in or out (depending on the configuration) to correct the water level.
