Pump upper threshold (Water Overlay)
Template:Overlay attribute This attribute can be defined as values over time, using an array of values defining interpolation-time. This allows users to more dynamically define the target water level this pump maintains.
- When the PUMP_Q of the pump is positive, the pump will not pump if the water level is higher than or equal to the upper threshold. If the PUMP_Q is negative, the pump will not pump if the water level is lower than or equal to the upper threshold.
