How to remove an Attribute
The right panel allows you to add remove Attributes. The top half displays existing Attributes, along with the option to remove them.
Many things in a Project, ranging from Stakeholders to Overlays to Constructions, have Attributes, allowing generic properties to be configured for them. For most kinds of data, Attributes can be added and edited in a similar fashion. After adding user-defined Attributes, those Attributes can be removed again as well.
Editor → The type of data to edit (Ribbon bar) → The data to edit (Left panel) → Attributes tab (Right panel)
How to remove an attribute:
  1. Select the type of data to remove an Attribute from.
  2. Switch to the "Attributes" tab.
  3. Scroll to the Attribute you want to remove, if neccesary.
  4. Click on "Remove" next to the Attribute you wish to remove.
  5. The Attribute has now been removed.
