Pump q (Water Overlay)
Revision as of 12:25, 2 October 2020 by Rudolf@tygron.nl (talk | contribs)
This attribute can be defined as values over time, using an array of values defining start-time. This allows users to more dynamically define the maximum throughput and operational direction of the pump.
  • The direction the pump pumps in can be reversed by configuring a negative PUMP_Q.
  • When using a dynamic PUMP_Q, a maximum of 10.000 values (5.000 pairs) can be defined.
