Pump capacity (Water Overlay)
Revision as of 16:22, 7 December 2020 by Frank@tygron.nl (talk | contribs)
Icon | Key | Unit | Range | Description | Default value |
INLET_CAPACITY | m3 | The maximum amount of water which can flow in or out through this construction. Water flowing back in the other direction replenishes the capacity. | 0 |
- This attribute name is used for both inlets and pumps.
- The capacity is a total allowed amount during the entire simulation. When the capacity is reached, no further water can flow through unless water flows in the opposite direction first.
- If the value is set to 0, there is no limit to this construction's capacity.
