Drainage (Water Overlay)
Revision as of 11:05, 12 January 2021 by Hansje@tygron.com (talk | contribs)
Drainages provide connections between the underground and nearby waterways, draining groundwater to levels which are optimal for agriculture. Drainage can be passive, where water drains based on water head differences, or active, where the water is pumped from the drain to the nearby waterway.
A drainage is a area-based construction.
Icon | Key | Unit | Range | Description | Default value |
DRAINAGE_Q | m3 per second | The maximum pump flow capacity, defined in cubic meters per second. | 1 | ||
DRAINAGE_DATUM | datum | -10000 to 10000 | The datum height (int meters) of the drainage. | -10000 | |
DRAINAGE_ACTIVE | boolean | 0 or 1 | Whether the drainage is actively pumped. | False | |
DRAINAGE_OVERFLOW_THRESHOLD | m + datum | -10000 to 10000 | The threshold of the water end-point of the drainage. | n/a |
- A drainage should have a part that overlaps with land and a part that overlaps with water.
