Drainage datum (Water Overlay)
Revision as of 11:17, 1 March 2021 by Rudolf@tygron.nl (talk | contribs)
Icon | Key | Unit | Range | Description | Default value |
DRAINAGE_DATUM | datum | The datum height of the drainage. | n/a |
Water can be drained out of the underground when it exceeds the drainage's datum height. Water in the underground lower than the drainage is out of reach, and cannot flow through the drainage.
- The drainage height should be higher than the bottom of the waterway it drains water to.
- If no height is defined, the drainage is considered to be low enough for all groundwater to flow into the waterway.
