Weir target level (Water Overlay)
WEIR_TARGET_LEVEL | m + datum | The Weir can be configured to adjust it's height automatically in order to reach the target upstream water level. This parameter is optional. | n/a |
- The interval before re-evaluating the Weir height is configured using the Water Overlay's model attribute Weir move interval s.
- This value is set as a single value, not an array.
- The weir can move with a distance defined in the overlay with the model attribute WEIR_MOVE_STEP_M.
- The weir's movement range can be set using the overlay's model attribute WEIR_MOVE_RANGE_M. This can be interpreted as the maximum allowed difference in the default WEIR_HEIGHT_M and the adjusted weir height.
