Project Sources
Revision as of 15:35, 30 January 2023 by Frank@tygron.nl (talk | contribs)
Project sources are the Geo data sets that can be used by (geo) plugins to generate and build up a project in the Tygron Platform. Project Sources are stored as Sources in your project. Furthermore, all the additional data users import into a project are tagged with new Source as well.
Default sources
The table below contains the datasets that are automatically accessed, depending on the selected location, to create a new project. When selecting a location outside The Netherlands it is more likely that some Geo data should be provided manually, which can done using a Template Project with one or more Geo Plugins.
(Open) Dataset Description Coverage (Connection) Source More information
BGT Basisregistratie Grootschalige Topografie: Base Register containining the topography of the Netherlands. The dataset is very detailed and contains for instance roads, parks, trees, water surfaces and street objects. Netherlands PDOK https://www.kadaster.nl/bgt; https://www.pdok.nl/introductie/-/article/basisregistratie-grootschalige-topografie-bgt-
BAG Basisregistraties Adressen en Gebouwen: Base Register containing data about buildings and addresses such as function, construction year, size and the geometry of the buildings. Netherlands. PDOK https://www.kadaster.nl/basisregistratie-adressen-en-gebouwen
BRO Basisregistratie Ondergrond: Base Register containing detailed subsurface data. Netherlands PDOK https://www.basisregistratieondergrond.nl/
World Imagery Satellite map used as base map for the heightmap in the 3D Visualization and used to identify rooftop colors. Worldwide ESRI https://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer/0
Ocean Basemap Basemap with ocean data, including locations of water bodies and their names. Used to determine the location of water bodies worldwide. Worldwide ESRI https://services.arcgisonline.com/arcgis/rest/services/Ocean_Basemap/MapServer
Terrain Digital Terrain Model (DTM): the terrain height of the bare ground without for example buildings, trees and other objects. See for more information the elevation model page. Worldwide ESRI http://www.arcgis.com/home/item.html?id=58a541efc59545e6b7137f961d7de883
AHN Actueel Hoogtebestand Nederland. By default AHN3 is used. We use the Digital Surface Model (DSM, the terrain height including buildings, trees and other objects) and the Digital Terrain Model (DTM, the terrain height of the bare ground) combined with the Terrain data above. For more information, see elevation model. Netherlands Nationaal Georegister https://www.ahn.nl/
CBS Wijk- en Buurtkaart The CBS Wijk- en Buurtkaart (2017) contains the geometry of the division in neighborhoods and statistical data related to those neighborhoods. Netherlands PDOK https://www.cbs.nl/nl-nl/dossier/nederland-regionaal/geografische%20data/wijk-en-buurtkaart-2017
Ruimtelijke plannen Ruimtelijke plannen are the offical published spatial plans/zoning plans. Netherlands Ruimtelijke Plannen http://www.ruimtelijkeplannen.nl/web-roo/roo/index
Top10NL Topographical dataset, used as an addition to the BGT data. Netherlands Tygron / PDOK https://www.kadaster.nl/-/top10nl
NWB The Nationaal Wegen Bestand is a dataset with the (name of) public roads in the Netherlands. Netherlands PDOK https://www.pdok.nl/introductie/-/article/nationaal-wegen-bestand-nwb-
NSL The NSL (Nationaal Samenwerkingsprogramma Luchtkwaliteit) contains data delivered by municipalities from their traffic models. For instance data such as road type, the tree factor, number of lanes, direction of traffic and traffic speed. Netherlands Rijksoverheid https://www.cimlk.nl/documentatie/
See also: Traffic Plugin
INWEVA The INWEVA 2020 data contains traffic intensity data for highways. Netherlands Rijkswaterstaat https://data.overheid.nl/dataset/31225-intensiteit-wegvakken--inweva--2020
Infomil The infomil excel contains a calculation model to estimate traffic intensities for roads, based on the type of road, nearby parking and bicycle paths and urbanization degree. This excel has been converted into a lookup table in the Tygron Platform. Netherlands Rijkswaterstaat https://www.infomil.nl/onderwerpen/lucht-water/luchtkwaliteit/slag/hulpmiddelen/inschatten/
BRP Gewaspercelen Basisregistratie Gewaspercelen: contains the location of agricultural land and the cultivated crops. Netherlands Nationaal Georegister http://www.nationaalgeoregister.nl/geonetwork/srv/dut/catalog.search#/metadata/%7B25943e6e-bb27-4b7a-b240-150ffeaa582e%7D?tab=general
BRK - Kadastrale Kaart Basisregistratie Kadaster. In the Tygron Platform the Kadastrale kaart is used to determine the location of parcels. Netherlands Nationaal Georegister http://www.nationaalgeoregister.nl/geonetwork/srv/dut/catalog.search#/metadata/40840197-0478-432b-8c76-e99c4da9203f?tab=general
Risicokaart This dataset shows the risks in a neighborhood, for example, by showing hazardous- and / or nuisance buildings (for example LPG station) and cables and pipes. Also contains additional information on vulnerable buildings (hotels, hospital, school, etc.). Netherlands Risicokaart.nl https://www.risicokaart.nl/home
OSM OpenStreetMap; this dataset contains the topography of the world and attribute information. Worldwide Own instance of Overpass API https://www.openstreetmap.org/
Waterschapsdata Several datasets from Water Authorities conforming to the Information Model Water (Informatiemodel water), including hydraulic structures and water-level areas. Netherlands - dataset does not cover the whole of the Netherlands yet. Copy of PDOK dataset https://www.pdok.nl/nl/introductie/-/article/waterschapsdata
3D Bag A dataset of 3D models covering the Netherlands, created by the 3D Geoinformation research group, Department of Urbanism at the Delft University of Technology. Netherlands 3D BAG https://docs.3dbag.nl/en/
Energy label data A dataset of most recently known energy labels per address in The Netherlands. Netherlands EP-online https://www.ep-online.nl/PublicData
Timezone data A dataset of time zones which is used to determine a project's time zone. World
More information on which sources are used
For more information on which project sources are actually used for the project, take a look at the following overviews in the editor:
