Attribute action panel
Revision as of 12:37, 20 February 2023 by Frank@tygron.nl (talk | contribs)
The Attribute action panel is a panel that is shown when a Stakeholder selects an Attribute Action from the Action menu panel. This panel can be used to draw a selection , which will be used to select buildings to which attributes from this Attribute Action will be set. Optionally, whether the Attribute Action is configured with a Fixed Value or not, the Stakeholder can adjust the attributes in the Attribute Action.
