Project Sources
Project sources are the Geo Data sets that can be used by (geo) plugins to generate and build up a project in the Tygron Platform. Project Sources are stored as Sources in your project. Furthermore, all the additional data users import into a project are tagged with new Source as well.
Default sources
The table below contains the datasets that are automatically accessed, depending on the selected location, to create a new project. When selecting a location outside The Netherlands it is more likely that some Geo Data should be provided manually, which can done using a Template Project with one or more Geo Plugins.
(Open) Dataset | Description | Coverage | (Connection) Source | More information |
BGT | Basisregistratie Grootschalige Topografie: Base Register containining the topography of the Netherlands. The dataset is very detailed and contains for instance roads, parks, trees, water surfaces and street objects. | Netherlands | PDOK | https://www.kadaster.nl/bgt; https://www.pdok.nl/introductie/-/article/basisregistratie-grootschalige-topografie-bgt- |
BAG | Basisregistraties Adressen en Gebouwen: Base Register containing data about buildings and addresses such as function, construction year, size and the geometry of the buildings. | Netherlands. | PDOK | https://www.kadaster.nl/basisregistratie-adressen-en-gebouwen |
BRO | Basisregistratie Ondergrond: Base Register containing detailed subsurface data. | Netherlands | PDOK | https://www.basisregistratieondergrond.nl/ |
World Imagery | Satellite map used as base map for the height map in the 3D Visualization and used to identify rooftop colors. | Worldwide | ESRI | https://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer/0 |
Ocean Basemap | Basemap with ocean data, including locations of water bodies and their names. Used to determine the location of water bodies worldwide. | Worldwide | ESRI | https://services.arcgisonline.com/arcgis/rest/services/Ocean_Basemap/MapServer |
Terrain | Digital Terrain Model (DTM): the terrain height of the bare ground without for example buildings, trees and other objects. See for more information the elevation model page. | Worldwide | ESRI | http://www.arcgis.com/home/item.html?id=58a541efc59545e6b7137f961d7de883 |
AHN | Actueel Hoogtebestand Nederland. By default AHN3 is used. We use the Digital Surface Model (DSM, the terrain height including buildings, trees and other objects) and the Digital Terrain Model (DTM, the terrain height of the bare ground) combined with the Terrain data above. For more information, see elevation model. | Netherlands | Nationaal Georegister | https://www.ahn.nl/ |
CBS Wijk- en Buurtkaart | The CBS Wijk- en Buurtkaart (2017) contains the geometry of the division in neighborhoods and statistical data related to those neighborhoods. | Netherlands | PDOK | https://www.cbs.nl/nl-nl/dossier/nederland-regionaal/geografische%20data/wijk-en-buurtkaart-2017 |
Ruimtelijke plannen | Ruimtelijke plannen are the offical published spatial plans/zoning plans. | Netherlands | Ruimtelijke Plannen | http://www.ruimtelijkeplannen.nl/web-roo/roo/index |
Top10NL | Topographical dataset, used as an addition to the BGT data. | Netherlands | Tygron / PDOK | https://www.kadaster.nl/-/top10nl |
NWB | The Nationaal Wegen Bestand is a dataset with the (name of) public roads in the Netherlands. | Netherlands | PDOK | https://www.pdok.nl/introductie/-/article/nationaal-wegen-bestand-nwb- |
NSL | The NSL (Nationaal Samenwerkingsprogramma Luchtkwaliteit) contains data delivered by municipalities from their traffic models. For instance data such as road type, the tree factor, number of lanes, direction of traffic and traffic speed. | Netherlands | Rijksoverheid | https://www.cimlk.nl/documentatie/ See also: Traffic Plugin |
INWEVA | The INWEVA 2020 data contains traffic intensity data for highways. | Netherlands | Rijkswaterstaat | https://data.overheid.nl/dataset/31225-intensiteit-wegvakken--inweva--2020 See also: Traffic Plugin |
Infomil | The infomil excel contains a calculation model to estimate traffic intensities for roads, based on the type of road, nearby parking and bicycle paths and urbanization degree. This excel has been converted into a lookup table in the Tygron Platform. | Netherlands | Rijkswaterstaat | https://www.infomil.nl/onderwerpen/lucht-water/luchtkwaliteit/slag/hulpmiddelen/inschatten/ See also: Traffic Plugin |
BRP Gewaspercelen | Basisregistratie Gewaspercelen: contains the location of agricultural land and the cultivated crops. | Netherlands | Nationaal Georegister | http://www.nationaalgeoregister.nl/geonetwork/srv/dut/catalog.search#/metadata/%7B25943e6e-bb27-4b7a-b240-150ffeaa582e%7D?tab=general |
BRK - Kadastrale Kaart | Basisregistratie Kadaster. In the Tygron Platform the Kadastrale kaart is used to determine the location of parcels. | Netherlands | Nationaal Georegister | http://www.nationaalgeoregister.nl/geonetwork/srv/dut/catalog.search#/metadata/40840197-0478-432b-8c76-e99c4da9203f?tab=general |
Risicokaart | This dataset shows the risks in a neighborhood, for example, by showing hazardous- and / or nuisance buildings (for example LPG station) and cables and pipes. Also contains additional information on vulnerable buildings (hotels, hospital, school, etc.). | Netherlands | Risicokaart.nl | https://www.risicokaart.nl/home |
OSM | OpenStreetMap; this dataset contains the topography of the world and attribute information. | Worldwide | Own instance of Overpass API | https://www.openstreetmap.org/ |
Waterschapsdata | Several datasets from Water Authorities conforming to the Information Model Water (Informatiemodel water), including hydraulic structures and water-level areas. | Netherlands - dataset does not cover the whole of the Netherlands yet. | Copy of PDOK dataset | https://www.pdok.nl/nl/introductie/-/article/waterschapsdata |
3D Bag | A dataset of 3D models covering the Netherlands, created by the 3D Geoinformation research group, Department of Urbanism at the Delft University of Technology. | Netherlands | 3D BAG | https://docs.3dbag.nl/en/ |
Energy label data | A dataset of most recently known energy labels per address in The Netherlands. | Netherlands | EP-online | https://www.ep-online.nl/PublicData |
Timezone data | A dataset of time zones which is used to determine a project's time zone. | World |
More information on which sources are used
For more information on which project sources are actually used for the project, take a look at the following overviews in the editor:
- the hover panel when clicking in the 3D Visualization in the default view.
- the Source Overlay
- the project source table (see below for more information)
- the project sources menu (see below for more information)
- How to open the Project Sources panel
- How to open the Project Sources table
- How to import i3s scene layer in new project
