Breach level area (Water Overlay)
Revision as of 08:10, 21 June 2023 by Frank@tygron.nl (talk | contribs)
  • To attach a breach level area to a breach using the configuration wizard, ensure that the desired level area does not have a BREACH_HEIGHT attribute but does have a BREACH_LEVEL_AREA attribute (set to -1, for example). That area is then selectable as an input area in the configuration wizard, in the step for breaches areas.
  • A breach level area should be placed on a relatively flat surface. The heights of the water columns across a breach level area are only inspected; they are never changed directly by the breach.
  • When a breach level area is not defined, the BREACH_MEASUREMENT_DISTANCE_M attribute in the Water Overlay is used to automatically place a point for measurement of the downstream water level.
