Inlet upper threshold (Water Overlay)
Revision as of 09:52, 25 January 2024 by Frank@tygron.nl (talk | contribs)
This attribute can be defined as values over time, using an array of values defining start-time. This allows users to more dynamically define the target water level this outlet maintains.
  • The INLET_Q should be 0 or negative. Otherwise, the Inlet is not configured to let water flow out.
  • When using a dynamic UPPER_THRESHOLD, a maximum of 10.000 values (5.000 pairs) can be defined.
