Water balance (Water Overlay)
Revision as of 09:25, 26 January 2024 by Frank@tygron.nl (talk | contribs)
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → The Water Overlay (Left panel) → General tab (Right panel) → Show water balance
Input Output
Bottom in Bottom Out
Breach Breach Breach Out Breach
Inundated Inundation Area Land Surface
Rain Rain m, Rain areas Evaporated
Building Storage
Sewer Storage
Sewer Out External
Inlet Outlet
Saturated Ground Storage Saturated Ground Storage
Unsaturated Ground Storage Unsaturated Ground Storage
Water surface Water surface
