Water balance (Water Overlay)
| Input | Output | ||
| Bottom in | Bottom Out | ||
| Breach | Breach | Breach Out | Breach |
| Inundated | Inundation Area | Land Surface | |
| Rain | Rain m, Rain areas | Evaporated | |
| Building Storage | Building storage | ||
| Sewer Storage | |||
| Sewer Out External | |||
| Inlet | Outlet | ||
| Saturated Ground Storage | Saturated Ground Storage | ||
| Unsaturated Ground Storage | Unsaturated Ground Storage | ||
| Water surface | Water surface |
