Water balance (Water Overlay)
![](/w/images/d/d0/Water_balance.jpg)
Input | Output | ||
Bottom in | Bottom Pressure and Resistance | Bottom Out | Bottom Pressure and Resistance |
Breach | Breach | Breach Out | Breach |
Inundated | Inundation Area | Land Surface | |
Rain | Rain m, Rain areas | Evaporated | |
Building Storage | Water Storage m2 | ||
Sewer Storage | Sewer storage | ||
Sewer Out External | Sewer pump speed | ||
Inlet | Inlet | Outlet | Outlet |
Saturated Ground Storage | Saturated Ground Storage | ||
Unsaturated Ground Storage | Unsaturated Ground Storage | ||
Water surface | Water surface |
