Water balance (Water Overlay)
Revision as of 09:40, 26 January 2024 by Frank@tygron.nl (talk | contribs)
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → The Water Overlay (Left panel) → General tab (Right panel) → Show water balance
Input Configuration Result Output Configuration Result
Water surface Water area, Surface level prequel Water surface
Rain Rain m, Rain areas Evaporated Evaporation m
Building Storage Water storage m2
Sewer Storage Sewer storage
Sewer Out External Sewer pump speed
Bottom in Bottom Pressure and Resistance Bottom Out Bottom Pressure and Resistance
Breach Breach Breach Out Breach
Inundated Inundation area Land Surface
Inlet Inlet Outlet Outlet
Saturated Ground Storage Saturated Ground Storage
Unsaturated Ground Storage Unsaturated Ground Storage
