Water balance (Water Overlay)
Input | Configuration | Result | Output | Configuration | Result |
Water surface | Water area, Surface level prequel | Water surface | Surface last value | ||
Rain | Rain m, Rain areas | Evaporated | Evaporation m | ||
Building Storage | Water storage m2 | ||||
Sewer Storage | Sewer storage | ||||
Sewer Out External | Sewer pump speed | Object flow output | |||
Bottom in | Bottom Pressure and Resistance | Bottom Out | Bottom Pressure and Resistance | ||
Breach | Breach | Object flow output | Breach Out | Breach | Object flow output |
Inundated | Inundation area | Surface last value | Land Surface | Surface last value | |
Inlet | Inlet | Object flow output | Outlet | Outlet | Object flow output |
Saturated Ground Storage | Saturated Ground Storage | ||||
Unsaturated Ground Storage | Unsaturated Ground Storage |
