Water balance (Water Overlay)
| Input | Configuration | Result | Output | Configuration | Result |
| Water surface | Water area, Surface level prequel | Water surface | Surface last value | ||
| Rain | Rain m, Rain areas | Evaporated | Evaporation m | ||
| Building Storage | Water storage m2 | ||||
| Sewer Storage | Sewer storage | Sewer last value | |||
| Sewer Out External | Sewer pump speed | Object flow output | |||
| Bottom in | Bottom Pressure and Resistance | Bottom Out | Bottom Pressure and Resistance | ||
| Breach | Breach | Object flow output | Breach Out | Breach | Object flow output |
| Inundated | Inundation area | Surface last value | Land Surface | Surface last value | |
| Inlet | Inlet | Object flow output | Outlet | Outlet | Object flow output |
| Saturated Ground Storage | Saturated Ground Storage | ||||
| Unsaturated Ground Storage | Unsaturated Ground Storage |
