Water balance (Water Overlay)
![](/w/images/d/d0/Water_balance.jpg)
Input | Configuration | Result | Output | Configuration | Result | |
Water surface | Water area, Surface level prequel | Water surface | Surface last value | |||
Rain | Rain m, Rain areas | Evaporated | Evaporation m | |||
Building Storage | Water storage m2 | [[Building last storage result type (Water Overlay) | Building last storage]] | |||
Sewer Storage | Sewer storage | Sewer last value | ||||
Sewer Out External | Sewer pump speed | Object flow output | ||||
Bottom in | Bottom Pressure and Resistance | Ground bottom flow | Bottom Out | Bottom Pressure and Resistance | Ground bottom flow | |
Breach | Breach | Object flow output | Breach Out | Breach | Object flow output | |
Inundated | Inundation area | Surface last value | Land Surface | Surface last value | ||
Inlet | Inlet | Object flow output | Outlet | Outlet | Object flow output | |
Saturated Ground Storage | Saturated Ground Storage | |||||
Unsaturated Ground Storage | Unsaturated Ground Storage |
