Water balance (Water Overlay)
Revision as of 09:46, 26 January 2024 by Frank@tygron.nl (talk | contribs)
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → The Water Overlay (Left panel) → General tab (Right panel) → Show water balance
Input Configuration Result Output Configuration Result
Water surface Water area, Surface level prequel Water surface Surface last value
Rain Rain m, Rain areas Rain Evaporated Evaporation m Evaporated
Building Storage Water storage m2 Building last storage
Sewer Storage Sewer storage Sewer last value
Sewer Out External Sewer pump speed Object flow output
Bottom in Bottom Pressure and Resistance Ground bottom flow Bottom Out Bottom Pressure and Resistance Ground bottom flow
Breach Breach Object flow output Breach Out Breach Object flow output
Inundated Inundation area Surface last value Land Surface Surface last value
Inlet Inlet Object flow output Outlet Outlet Object flow output
Saturated Ground Storage Saturated Ground Storage
Unsaturated Ground Storage Unsaturated Ground Storage
