Water balance (Water Overlay)
![](/w/images/d/d0/Water_balance.jpg)
Input | Configuration | Result | Output | Configuration | Result |
Water surface | Water area, Surface level prequel | Water surface | Surface last value | ||
Inundated | Inundation area | Surface last value | Land Surface | Surface last value | |
Rain | Rain m, Rain areas | Rain | Evaporated | Evaporation m | Evaporated |
Building Storage | Water storage m2 | Building last storage | |||
Sewer Storage | Sewer storage | Sewer last value | |||
Sewer Out External | Sewer pump speed | Object flow output | |||
Breach | Breach | Object flow output | Breach Out | Breach | Object flow output |
Inlet | Inlet | Object flow output | Outlet | Outlet | Object flow output |
Bottom in | Bottom Pressure and Resistance prequels | Ground bottom flow | Bottom Out | Bottom Pressure and Resistance prequels | Ground bottom flow |
Saturated Ground Storage | Saturated Ground Storage | ||||
Unsaturated Ground Storage | Unsaturated fraction, prequel | Ground last unsaturated storage | Unsaturated Ground Storage | Ground last unsaturated storage |
