Culvert (Watershed Overlay)
Revision as of 16:53, 2 February 2024 by Frank@tygron.nl (talk | contribs)
Culverts are assumed to have a circular cross-section, and level (i.e. not inclined).
A culvert is a line-based building.
  • If a culvert is placed in a waterway, and the waterway is not otherwise interrupted, water will be able to flow past the culvert via the waterway itself. It is recommended to make sure that the waterway is obstructed by an increase in the terrain height in such a way that the only way water can flow from the one end of the culvert to the other is via the culvert.
