Drainage (Water Overlay)
Revision as of 16:39, 11 December 2024 by Maxim@tygron.com (talk | contribs)
Drainages provide connections between the saturated ground layer and nearby waterways, draining groundwater to levels which are optimal for agriculture. Drainage can be passive, where water drains based on water head differences, or active, where the water is pumped from the drain to the nearby waterway.
A drainage is an area-based building.
Drainage diameter (Water Overlay)
  • A drainage should have a part that overlaps with land and a part that overlaps with water. These should be two separate polygons. Neither polygon should overlap with the edge of the waterway.
There are three use cases that can be modeled using a drainage:
Passive Drainage
A passive drainage lets water flow from the drainage pipes into the waterway. I should therefor always have a positive Drainage Q. Note: when the waterway level is higher then the Drainage datum (Water Overlay) flow into the pipes is blocked.
Active Drainage Negative Q
A active drainage with a negative Drainage Q can pump water from from the waterway (with a lower level) up into the drainage pipes.
The pump will keep pumping until:
Active Drainage Positive Q
A active drainage with a positive Drainage Q can pump water from the drainage pipes up into a waterway (with a higher level).
