Drainage active (Water Overlay)
Revision as of 16:44, 11 December 2024 by Maxim@tygron.com (talk | contribs)
An actively pumped drainage will be able to move groundwater into the open water, even if the surface water level is higher than the ground water level. A passive drainage effectively just allows water flow based on water head differences.
