Drainage q (Water Overlay)
Icon | Key | Unit | Range | Description | Default value |
DRAINAGE_Q | m3 per second | The drain capacity per second, where the capacity is defined in cubic meters per square meter. | 1 |
This attribute can be defined as values over time, using an array of values defining interpolation-time. This allows users to more dynamically define the drainage used to allow or deny water flowing across.
- When using a dynamic DRAINAGE_Q, a maximum of 10.000 values (5.000 pairs) can be defined.
