Scenario
By default, a project in the Tygron Platform always consists of at least one scenario.
When you have multiple Scenarios, for example with two different designs for you project, you can switch between them from the ribbon bar in the editor. Currently, only one scenario can be active at the same time. Actions taken in a different scenario are reverted.
Limit Map
Scenario's can be limited to a specific part of the map by selecting 'Measure Neighborhoods' in the Editor. This way only Neighborhoods that are covered by measures are active in the Scenario and the map is limited to these Neighborhoods. Using the margin attribute a margin can be added around the Neighborhoods.
The attributes and description of an active Scenario are persistent (not reset) when stopping the testrun. This allows users to store attributes for later comparison between Scenario's.
- Scenarios are intended to become parallel planned situations
- Scenarios replaced the incremental Level system.
- How to add or remove a Scenario
- How to change properties of a Scenario
- How to change Events fired by a Scenario
- How to change Measures activated by a Scenario
- How to configure the available actions of a stakeholder per scenario
- How to configure an intro Cinematic for a Stakeholder and a Scenario
