How to create a Panel for some of an Item type
When multiple Items of the same type need to be endowed with a Panel, either to display related information or to allow the end-user to effect changes to it, it is possible to create such Panels manually. However, it is much easier to have the Panels generated automatically based on Template Panels.
This also holds true if not all Items of the specified type should be provided a Panel. Filters can be applied if the Items which should have a Panel either share the existance of a specific Attribute, or all share a common related Stakeholder.
How to automatically create a Panel for each of an Item type:
- Add a Template Panel to the Project.
- Configure the Template Panel with the content desired for each instance.
- Set the Template Panel's "Apply Template on" value to the Item type you want Panels to be created for.
- If the Items which should have a Panel all share an Attribute, set the Attribute filter to that Attribute.
- If the Items which should have a Panel all share a specific relation with a specific Stakeholder, set the owner of the Template Panel to that Stakeholder,
and set the relational filter to the relation type the Stakeholder should have to the Item. - Click on "Apply Template", and confirm the prompt.
- Each Item of the specified type should now have an instance of the Template Panel.
