Tygron Query Language
This article is a stub.
Queries
Clauses
The following groups of clauses exist:
Specific polygons
Clause As a polygon As an item Type
AREA The requested data must intersect with this area. It must be data of this area specifically. ID indicating a specific area.
NEIGHBORHOOD The requested data must intersect with this neighborhood. It must be data of this neighborhood specifically. ID indicating a specific neighborhood.
ZONE The requested data must intersect with this zone. It must be data of this zone specifically. ID indicating a specific zone.
TERRAIN The requested data must intersect with this terrain type. It must be data of this type of terrain. There are no specific "instances" of terrain. ID indicating a type of terrain.
Unspecific polygons
AREA_WITH_ATTRIBUTE It must intersect with at least one area with this attribute. N/A Attribute name of one or more areas.
NEIGHBORHOOD_WITH_ATTRIBUTE It must intersect with at least one neighborhood with this attribute. N/A Attribute name of one or more neighborhoods.
ZONE_WITH_ATTRIBUTE It must intersect with at least one zone with this attribute. N/A Attribute name of one or more zones.
TERRAIN_WITH_ATTRIBUTE It must intersect with terrain with this attribute. N/A Attribute name of one or more terrains.
Grids
MAXGRIDVALUE It must intersect with at least this value on a grid overlay. N/A Decimal number.
MINGRIDVALUE It must intersect with at most this value on a grid overlay. N/A Decimal number.
GRID It must fall within this grid. It must be data of this grid overlay specifically. ID indicating a specific zone.
GRIDTYPE It must fall within this type of grid. It must be data of this type of grid, not a specific "instance" of this grid. Technical name indicating a type of grid overlay.
Note that each grid automatically covers the entire map, unless a minimum gridvalue or maximum gridvalue is defined. For queries such as GRIDAVG, this can be acceptable. However, for example, a query of SELECT_LANDSIZE_WHERE_GRID_IS_2 is functionally the same as SELECT_LANDSIZE.
Also note that when a GRIDTYPE is selected but multiple overlays of that type exist in the project, there are no guarantees on which overlay is used specifically.
Constructions
BUILDING It must intersect with this construction. It must be data of this construction specifically. ID indicating a specific construction.
NET_LOAD It must intersect with the building of this net load. It must be data of this net load specifically. ID indicating a specific net load.
NET_CLUSTER It must intersect with buildings of net loads of this net cluster. It must be data of this net cluster specifically. ID indicating a specific net cluster.
FUNCTION It must intersect with constructions of this function. It must be data related to this function type. ID indicating a specific function.
ATTRIBUTE_MAX It must intersect with at least this value of an attribute. N/A Decimal number.
ATTRIBUTE_MIN It must intersect with at most this value of an attribute. N/A Decimal number.
ATTRIBUTE The attribute of which to test the value. N/A Attribute name of any polygonal item.
When neither a maximum or minimum value is specified, or when no attribute is specified, everything is considered
Multipliers
ATTRIBUTE_MULT Multiply the result by the (spatial) value of an attribute. N/A Attribute name of any polygonal item.
FUNCTIONMULT Multiply the result by the (spatial) value of an attribute. N/A The name of a function value.
CATEGORYMULT Multiply the result by the (spatial) value of an attribute. N/A The name of a category value.
Net line
NET_LINE N/A It must be data of this net line specifically. ID indicating a specific net line.
NET_LINE_DEFINITION N/A It must be data of net lines of this definition. ID indicating a line definition.
NET_TYPE N/A It must be data of net lines of this type of network. ID indicating the type of network.
Stakeholder
STAKEHOLDER The land must be owned by this specific stakeholder. It must be data of this stakeholder specifically. ID indicating a specific stakeholder.
STAKEHOLDERTYPE The land must be owned by this type of stakeholder. N/A Technical name indicating a type of stakeholder.
Interface
INDICATOR N/A It must be data of this indicator specifically. ID indicating a specific indicator.
OVERLAY N/A It must be data of this overlay specifically. ID indicating a specific overlay.
PANEL N/A It must be data of this panel specifically. ID indicating a specific panel.
