Queries
Clauses
The following groups of clauses exist:
Specific polygons
Clause
As a polygon
As an item
Type
AREA
The requested data must intersect with this area.
It must be data of this area specifically.
ID indicating a specific area.
NEIGHBORHOOD
The requested data must intersect with this neighborhood.
It must be data of this neighborhood specifically.
ID indicating a specific neighborhood.
ZONE
The requested data must intersect with this zone.
It must be data of this zone specifically.
ID indicating a specific zone.
TERRAIN
The requested data must intersect with this terrain type.
It must be data of this type of terrain. There are no specific "instances" of terrain.
ID indicating a type of terrain.
Unspecific polygons
Clause
As a polygon
As an item
Type
AREA_WITH_ATTRIBUTE
It must intersect with at least one area with this attribute.
N/A
Attribute name of one or more areas.
NEIGHBORHOOD_WITH_ATTRIBUTE
It must intersect with at least one neighborhood with this attribute.
N/A
Attribute name of one or more neighborhoods.
ZONE_WITH_ATTRIBUTE
It must intersect with at least one zone with this attribute.
N/A
Attribute name of one or more zones.
TERRAIN_WITH_ATTRIBUTE
It must intersect with terrain with this attribute.
N/A
Attribute name of one or more terrains.
Grids
Clause
As a polygon
As an item
Type
MAXGRIDVALUE
It must intersect with at least this value on a grid overlay.
N/A
Decimal number.
MINGRIDVALUE
It must intersect with at most this value on a grid overlay.
N/A
Decimal number.
GRID
It must fall within this grid.
It must be data of this grid overlay specifically.
GRIDTYPE
It must fall within this type of grid.
It must be data of this type of grid, not a specific "instance" of this grid.
Technical name indicating a type of grid overlay.
Note that each grid automatically covers the entire map, unless a minimum gridvalue or maximum gridvalue is defined. For queries such as GRIDAVG, this can be acceptable. However, for example, a query of SELECT_LANDSIZE_WHERE_GRID_IS_2 is functionally the same as SELECT_LANDSIZE.
Also note that when a GRIDTYPE is selected but multiple overlays of that type exist in the project, there are no guarantees on which overlay is used specifically.
Constructions
Clause
As a polygon
As an item
Type
BUILDING
It must intersect with this construction.
It must be data of this construction specifically.
ID indicating a specific construction.
NET_LOAD
It must intersect with the building of this net load.
It must be data of this net load specifically.
ID indicating a specific net load.
NET_CLUSTER
It must intersect with buildings of net loads of this net cluster.
It must be data of this net cluster specifically.
ID indicating a specific net cluster.
FUNCTION
It must intersect with constructions of this function.
It must be data related to this function type.
ID indicating a specific function.
Clause
As a polygon
As an item
Type
ATTRIBUTE_MAX
It must intersect with at least this value of an attribute.
N/A
Decimal number.
ATTRIBUTE_MIN
It must intersect with at most this value of an attribute.
N/A
Decimal number.
ATTRIBUTE
The attribute of which to test the value.
N/A
Attribute name of any polygonal item.
When neither a maximum or minimum value is specified, or when no attribute is specified, everything is considered
Net line
Clause
As a polygon
As an item
Type
NET_LINE
N/A
It must be data of this net line specifically.
ID indicating a specific net line.
NET_LINE_DEFINITION
N/A
It must be data of net lines of this definition.
ID indicating a line definition.
NET_TYPE
N/A
It must be data of net lines of this type of network.
ID indicating the type of network.
Stakeholder
Clause
As a polygon
As an item
Type
STAKEHOLDER
The land must be owned by this specific stakeholder.
It must be data of this stakeholder specifically.
ID indicating a specific stakeholder.
STAKEHOLDERTYPE
The land must be owned by this type of stakeholder.
N/A
Technical name indicating a type of stakeholder.
Interface
Clause
As a polygon
As an item
Type
INDICATOR
N/A
It must be data of this indicator specifically.
ID indicating a specific indicator.
OVERLAY
N/A
It must be data of this overlay specifically.
ID indicating a specific overlay.
PANEL
N/A
It must be data of this panel specifically.
ID indicating a specific panel.
Data manipulation clauses
Item
Clause
As a polygon
As an item
Type
RELATION
N/A
Rather than data of the specified item, use the item which has this relation to it.
Technical name indicating a type of relation.
