Culvert (Water Overlay)
Culverts are assumed to have a circular cross-section, and level (i.e. not inclined).
CULVERT_DIAMETER | m | 0 to 10000 | The inside diameter of the circular-shaped Culvert, or the inside width of a rectangular-shaped Culvert. | 1 |
CULVERT_RECTANGULAR_HEIGHT | m | 0 to 10000 | The inside height of a rectangular shaped Culvert. | 0 |
CULVERT_THRESHOLD | m + datum | -10000 to 10000 | The height of the inner side of the culvert's underside (or the threshold height at which water starts flowing through the culvert). When set to a level below the terrain height at either end-point, the culvert's threshold will automatically attain a value equal to that of the highest terrain found at either of its endpoints. | 0 |
CULVERT_N | manning value | 0 to 3.4028235E38 | The manning friction value of the culvert's material, which influences the flow speed. | 0,014 |
- If a culvert is placed in a waterway, and the waterway is not otherwise interrupted, water will be able to flow past the culvert via the waterway itself. It is recommended to make sure that the waterway is obstructed by an increase in the terrain height in such a way that the only way water can flow from the one end of the culvert to the other is via the culvert.
- How to correct multiple constructions on the same location
- How to correct weir, pump, or culvert drawn as point
- How to correct a construction in an uninterrupted waterway
- How to correct a construction at the edge of the project area
- How to correct a culvert connecting two water level areas
