Tag
Text in Panels can contain special tags that are replaced by the Tygron Platform based on the Project's data, the Session's data, and the context of the Panel, such as the owner or related Items of the Panel. A tag can be placed anywhere in the text of a Panel, and when the content of that Panel is rendered for display to the user, the tag is replaced by the appropriate data. In other words, the tag specifies a specific kind of data, and that data is inserted into the Panel's text in the location of the tag. TQL tags are calculated when the simulation is updated.
TQL tags
Tag Effect
$SELECT_LANDSIZE_WHERE_NEIGHBORHOOD_IS_0 Inserts area of the Neighborhood with ID 0. e.g. '100.0'
$SELECT_LANDSIZE_WHERE_NEIGHBORHOOD_IS_X Inserts areas of all Neighborhoods. e.g. '100.0, 200.0, 15.0'
General tags
Tag Effect
$PROJECT_NAME Inserts the name of the Project.
$TOKEN Inserts the API Token of the Project's Session.
$SESSION Inserts the url web endpoint of the Project's Session.
Web tags
Tag Effect
$LIB_CUSTOM Inserts the name of the custom javascript library, part of the web interface configuration.
Contextual tags
Tag Effect
$NAME Inserts the name of the Item the Panel is related to.
If not used with a Template Panel, an empty string is inserted.
$ID Inserts the ID of the Panel.
If not used with a Template Panel, "-1" is inserted.
$STAKEHOLDER_ID Inserts the ID of the user's Stakeholder.
$STAKEHOLDER Inserts the name of the user's Stakeholder.
Attributes tags
Tag Effect
$ATTRIBUTE_ATTRIBUTENAME, where ATTRIBUTENAME is the name of the Attribute. Inserts the value of the indicated Attribute of the Item the Panel is related to.
If the Attribute does not exist for the Item, an empty array is inserted, i.e. "[]". If not used with a Template Panel, the tag is not replaced.
$GLOBAL_GLOBALNAME, where GLOBALNAME is the name of the Global. Inserts the value of the indicated Globals. If the Global does not exist, it is considered "0".
  • Tags can also be used in the output of Panels based on an Excel, and in Indicators.
  • Text in the output which starts with a dollar-sign (like a tag) but is not explicitly a tag to the Tygron Platform, is not replaced or overwritten.
  • Attribute and Global values are inserted with at least one decimal. I.e. "2" and "2.203" are displayed as "2.0" and "2.203" respectively.
  • If an Attribute is inserted which does not have exactly one value (i.e. does not exist, or is an Attribute array with multiple values), an array of values is inserted compatible with a javascript array definition.
