Water Overlay
A water overlay is an implementation of a number of hydrological formulas which together can simulate the flow of water across large areas with a high level of detail. These formulas combined form the model that is part of the Water Module in the Tygron Platform. Its calculations form a simulation of an arbitrary amount of time, during which water is allowed to move.
Water flow is affected by properties of the surface across which it flows, including the terrain height and the properties of the underlying terrain.
Different water overlays
The water module can be called upon by adding one of the following overlays to a project. Each variant has a number of parameters tuned to best fit specific use-cases.
  • The Rainfall Overlay, provides insight into the water stress and impact caused by (excessive) rainfall.
  • The Flooding Overlay, provides insight into water stress and impact caused by breaches in levees or other sources causing excessive water inflow.
  • The Groundwater Overlay, provides insight into long-term processes of water flow both on the surface and underground.
Results
See results and result types.
Use cases
Use cases Water Overlay
