Water Overlay
Revision as of 08:29, 11 April 2019 by Frank@tygron.nl (talk | contribs)
A water overlay is an overlay of which results are calculated by the Water Module. The Water Module in the Tygron Platform is an implementation of a 2D grid based shallow water model based on the 2D Saint Venant equations. The module is further enhanced with infiltration, evaporation, groundwater flow and hydraulic structures. Its calculations form a simulation of an arbitrary amount of time, during which water is allowed to move.
Water flow is affected by properties of the surface across which it flows, including the terrain height and the properties of the underlying terrain.
Variants
The water module can be called upon by adding one of the following overlays to a project. Each variant has a number of parameters tuned to best fit specific use-cases.
Results
A water overlay generates different results. For further information about these outcomes, see also results and result types.
