Water Overlay
A Water Overlay is an overlay for which results are calculated by the Water Module. The Basic theory of the Water Module in the Tygron Platform is an implementation of a 2D grid based shallow water model based on the 2D Saint Venant equations. The module is further enhanced with infiltration, evaporation, groundwater flow and hydraulic structures. Its calculations form a simulation of an arbitrary amount of time, during which water is allowed to move.
Variants
The Water Module can be called upon by adding one of the following overlays to a project. Each variant has a number of parameters tuned to best fit specific use-cases.
| Rainfall Overlay | provides insight into the water stress and impact caused by (excessive) rainfall | |
| Flooding Overlay | provides insight into water stress and impact caused by breaches in levees or other sources causing excessive water inflow | |
| Groundwater Overlay | provides insight into long-term processes of water flow both on the surface and underground |
Results
With a Water Overlay, one can generate different kinds of results. For further information about these outcomes, see also results and result types.
- Add and remove an overlay
- Configure a Water Overlay
- Use a Water Overlay
- Edit an overlay legend
- Combine with Subsidence Overlay
