Measure
Revision as of 10:40, 30 January 2023 by Frank@tygron.nl (talk | contribs)
A measure can be used to:
  • Placing Buildings. These buildings will be linked to the measure;
  • Execute terrain adjustments. Stored in measure as MeasureSpatials;
  • Applying changes in elevation using GeoTIFFs. Stored in measure as TiffSpatials;
  • Upgrade existing Buildings that overlap the defined upgrade selection; Stored in measure as UpgradeSpatials;
  • Placing Levees with side and top functions; Stored in measure as LeveeSpatials;
  • Execute Server events. Stored in measure with two lists: one for when measure is constructed and one for when measure is cancelled.
A measure is an action, which means it can be added to an action menu. Also, measures can be activated indirectly using events. Thirdly, they can be activated directly in the editor by click on the Activate Measure link:
Editor → Future Design (Ribbon tab) → Measures (Ribbon bar) → Measure → General
When to use measures
(In Dutch)
Creating and editing measures
Advanced usage of measures
Not showing spatial effects
Normally, when a user selects a measure in their action menu, the spatial effects of that measure are shown. This means locations on the map where the measure has its effect are highlighted, and the user's camera is moved to that location. However, this may not always be necessary or desirable. To prevent this, it is possible to implement the measure as two measures. A first measure, with the proper costs and description, which the stakeholder will see in the action menu. A second measure is not directly visible to the stakeholder, but has the actual spatial effect. The first measure can then, upon activation, trigger the activation of the second measure.
Reusing measures
Using the above principle, it is also possible to reuse measure. If multiple measures would have the same spatial effect, it is possible to have an additional measure in which the actual spatial effect is defined. All measures which should have that spatial effect can trigger the additional measure. This has the benefit of being easier to maintain if the spatial effect needs to change. Any change to the plan would only require a change to a single measure, instead of all measures which have the same effect.
(In Dutch)
