Select attribute (TQL)
| Select | Unit | Description | Fixed clause amount | Polygon based |
Allowed clause parameters
| Param | Type | Description | Limits search polygon |
| TERRAIN | Item ID | Terrain of Terrain Type with ID | true |
| AREA | Item ID | Area with ID | true |
| ZONE | Item ID | Zone with ID | true |
| NEIGHBORHOOD | Item ID | Neighborhood with ID | true |
| BUILDING | Item ID | Building with ID | false |
| ADDRESS | Item ID | Address with ID | false |
| FUNCTION | Item ID | Function with ID | false |
| PANEL | Item ID | Panel with ID | false |
| NAME | String | Only a specific name | false |
| NET_LINE | Item ID | Net line with ID | false |
| NET_LOAD | Item ID | Net Load with ID | false |
| NET_FUNCTION | Item ID | Net Function with ID | false |
| NET_CLUSTER | Item ID | Net Cluster with ID | true |
| NET_TYPE | Net type | Only net items of this net type | false |
| MAP | Map Type | Only items present in this Map Type | true |
| INDICATOR | Item ID | Indicator with ID | false |
| RELATION | Relation | Allows to convert a specific selected item to an other item it is related to. | false |
| INDEX | positive integer | Allows to specify which value in an attribute' s value array to select. | false |
| MEASURE | Item ID | Measure with ID | false |
| GRID | Item ID | Grid of Grid Overlay with ID | false |
| GRID_WITH_ATTRIBUTE | Attribute | Grid of Grid Overlay with non zero Attribute value | false |
| TIMEFRAME | timeframe | Specifies which timeframe to select when processing a particular Grid | false |
