Waterwijzer Overlay
The waterwijzer overlay provides the yield loss of crops based on several input parameters. The yield loss is currently calculated by the Waterwijzer Landbouw module, which is described here.
Usage
The Waterwijzer Overlay results can be used to:
- Calculate the yield loss based on existing crops for currently known highest and lowest groundwater levels.
- Calculate the yield loss for crops when using different groundwater level management strategies simulated by a Groundwater Overlay or a Subsidence Overlay.
- Determine the best type of crop per parcel given the highest and lowest groundwater levels and type of soil.
Considerations
The Waterwijzer Overlay calculates yield loss for agriculture crops based on:
- A climate scenario;
- A weather station;
- Type of soil;
- Type of crop;
- Highest and lowest (averaged) groundwater levels;
Additionally:
- The Overlay makes use specifically of version 2.0.0 of the Waterwijzer tool.
- The irrigation parameter, which in the Waterwijzer tool is active for a number of the crop types, is currently not taken into account.
Result types
The overlay offers multiple result types. Each result type expresses the yield loss due to specific circumstances as a percentage.
Icon | Result type | Unit | Mode | Description |
DAMAGE_DRY | % yield loss | The loss of agricultural yield due to low groundwater levels. | |
DAMAGE_WET | % yield loss | The loss of agricultural yield due to high groundwater levels. | |
DAMAGE_INDIRECT | % yield loss | The loss of agricultural yield due to indirect causes. | |
DAMAGE_SALT | % yield loss | The loss of agricultural yield due to salt water irrigation or ground bottom flow with salt water. | |
DAMAGE_TOTAL | % yield loss | The total loss of agricultural yield for a particular crop. |
- How to add the Waterwijzer Overlay
- How to configure the Waterwijzer Overlay to use groundwater results from other calculations
Module
A Waterwijzer Overlay can be configured by opening the Waterwijzer Overlay Wizard. More in-depth information can be found under each of the categories below.
